G
gvdv
Member
Hi,
I'm new to this forum, and to the whole world of DAW specifically (although I've been recording in the analogue world on-and-off for a few years, and have recently been recording with a friend on his DAW).
After having researched the various options for moving to digital recording for the last few months, I have finally decided to go with a DAW, and would like some advice on the kinds of components I should be looking at.
My needs are these:
1. Ability to record mostly analogue sources (i.e., plugging in guitars, drum
machines, keyboards etc.), and to INPUT 4 SOURCES SIMULTANEOUSLY,
PREFERRABLY 8 IF THAT IS POSSIBLE
2. Flexibility to also use MIDI (although this will not be the main emphasis)
3. Facility to process audio for video, too
4. Ability to burn to DVD, create mp3's, WMA's, WMD's etc..
5. Most of budget is to go on computer and other necessary recording
equipment, i.e., separate mixer, if necessary. I am willing to compromise
by NOT buying a 19" monitor, and by using some cheap - but good -
software like N-Track until I can afford to upgrade
6. Budget of approximately $1000-$1500 U.S. ($1500-$2000 CAN.)
I have looked at some of the M-Audio cards and don't really see anything there that suits my needs.
QUESTIONS
Given the above, here are my questions
1. What are systems like that are specifically built as DAW's - e.g.,
Carillon computers (www.carillonusa.com) makes just such a system?
2. Is it possible to effectively build a system like this myself, copying the
components?
3. What are some stable chipset / motherboard configurations?
4. What kind of speed chip will I need to run 16 tracks simultaneously and
well? (I saw a formula earlier today somewhere on the N-track users
group for calculating this generally, but am unsure of its accuracy)
5. What kind of outboard/physical equipment will I need in addition to the
computer, and sound card - most people seem to talk about a good mixer
with good pre-amps (what difference does this make in the 'real' world?)
6. Are there any other considerations that I haven't mentioned? (make of
fan that is quieter than others? Motherboard that has noisier components
like fan positioned physically as far away from hard drive as possible?
Makes of hard drive to look out for - I presume that a 7200 is minimum
requirement? Does the quality of the tower/case make a difference?)
7. What could I compromise on if I had to (I'm thinking preamps here)?
I appreciate any contributions or information no matter how basic you think it is, because I would like to make an informed decision.
Many thanks,
Geert, in Toronto
www.CollaborativeTherapy.com
My needs are these:
QUESTIONS
components?
Many thanks,
Geert, in Toronto
