A
Aspirations
Sorry this post is so long but I will greatly appreciate any help I can get with this question. I have read everything I can get my hands on…all the books and articles on mixing and EQ I can find…and still can’t overcome this problem.
I have been working quite awhile at trying to learn how to create mixes that sound more professional and sound more consistent across the different systems that I play them on. I have the classic problem of sounds (relatively) okay on the system I use to mix it but sounds like garbage on almost everything else I play it. I believe that it is mostly an EQ issue. I know compression can give a recording more punch and make it louder but I don’t think that is the problem I’m hearing. Let me start by explaining my process.
When I’m creating my recording, I usually have some idea of the sound I want for each part (we’re talking primarily electric guitar). Its usually a tone/sound that I’m referencing from a commercial CD. I try to get my sound as close as I can with the gear I have by monitoring my signal and the commercial source through the same speakers. Often I can’t get very close but I come up with something I hope is decent. Once I get as close as I can I record it. Then I use a parametric EQ plug-in (Cakewalk) to try and fine-tune it more closely, again listening to my recording and the commercial “reference” through the same amp/speakers. This is where my real problem starts. I can never find the settings to get me there. I have all the guides about where to boost and cut to make it more/less nasal, more/less airy, more/less warm…etc. But I always just end up sweeping up and down with enough gain or cut that I can hear a real difference and getting nowhere. This is the first thing I would like help with. It just seems like there are too many combinations and permutations of frequencies and levels to boost and cut for me to ever stumble onto the same or even similar sound as the reference. Is there any tool I can use to help me analyze and compare the spectrum of the two recordings; is that the right approach to take? Or am I making it too hard. Somehow I can’t see Daniel Lanois (my own personal Tone-God) doing such a thing. Should I being using a parametric or a graphic EQ? Any suggestions?
Now, the next part of my question. In the few cases where I get somewhat close to where I think I may have matched my commercial reference, it still sounds like garbage when played on a different system…yet my commercial reference will sound reasonably, or relatively, good on that system. Its especially bad when played on a system that is inferior to the one I used for mixing. Which brings me to the next question. I’m using a budget-priced consumer receiver and inexpensive Infinity bookshelf speakers for mixing. My theory was that if I made my track sound like the commercial track through this system it would also sound like it when played on another system. But that doesn’t seem to be the case. Obviously there is something I am missing about what you get out of studio monitors…apparently my track sounds even less like the commercial track than the limitations of my speakers will allow me to hear. So the idea that just knowing your speakers is sufficient is flawed. Not that I ever really doubted that, just trying to understand why it is. Do cheaper speakers just lump the frequencies together more and then it becomes apparent that you really weren’t hearing what was actually there when you move it to another system that lumps it together wrong in a different way? Does this make any sense? I’m more or less ready to make the investment in monitors but I like to try to get as good as I can with what I’ve got so when I get something new I can really take off…plus understanding this better should really help me decide what to buy. So any help will be greatly appreciated. Again, my questions are:
1) recommended technique for eq’ing a signal to match a reference recording
2) more insight into resolving the “amateur sound / mix doesn’t translate” problem and how quality studio monitors help you get there versus matching a reference on regular hi-fi speakers
