K
Keaction
Hi guys, I have an issue with white noise while doing simple recordings at home.
My current setup is Mic -> M audio mobile pre (discontinued) -> Laptop's USB -> DAW
If i want to get the signal to a good level, the white noise becomes extremely audible when I turn up the gain on the pre amp.
Now I understand that my pre amp is an entry level gear, but I just want to confirm if the M audio mobile pre really is the culprit or is there other influences? Say if I upgrade to a hight quality interface such as the RME babyface, will this problem be gone?
EDIT: I just checked the m audio mobile pre's manual and it says the pre amp's S/N ratio is 91 dB. Based on that number it shouldn't be so noisy should it?
I am using a good mic and good quality canare cable, so those 2 I've eliminated. But whats bothering me is that could it have something/anything to do with my laptop and it's internal hardware?
Cheers,
Cheers,
