M
mayim
Hi. This should be easy- I have a Shure Prologue 16L, bought second hand, worked fine for about a year, then- doesn't work... I understand this mic has a battery, I found this, the manual for the 16A (looks the same):
http://www.shure.com/stellent/groups/public/@gms_gmi_web_ug/documents/web_resource/us_pro_16a_ug.pdf
Cryptically (or not so), the manual says: "To replace battery, unscrew and remove cartridge (top portion), replace the old battery with a new battery making sure the positive end is facing the cartridge, then screw the cartridge back on."
This shouldn't be difficult!!! I can't do it.
The windscreen comes off without a problem, then nothing. There is a small set screw, probably not good to remove, when I removed it nothing happened. It looks as though it should also unscrew below the label- this seems a logical place for it to open and have the battery. Even gently but firmly clamped in the wood mouth in my desk vice, this refuses to budge. I like this mic!!! it sounds great on acoustic instruments, and I don't have another like it-
Has anyone replaced the battery in this mic and can you tell me what you did??
Eternal gratefulness awaits you.
Thanks.
Thank you.
YOU'RE FANTASTIC.
If you can help. Thanks.
Thanks.
Thank you.
YOU'RE FANTASTIC.
