Help Repairing a Shure SM57 Unidyne III. Lots of Pictures included!
  • Thread starter Thread starter NathanPonzar
N
NathanPonzar
Hey everyone.
I was hoping that maybe someone has had some experience repairing shure SM57s. I bought a broken one off ebay as a kind of project. It's proving to be a little more difficult than I thought it would be.
I put up what I think are the best pictures I can get, tried to get a variety of angles. Really, where I am stuck now is that there seem to be 4 wires coming out down by the XLR pins, only 3 of which are attached to the XLR connectors (properly) and then there is 1 wire just hangin out with a loose end. I don't think it's supposed to be attached to the 4th XLR tab because it has no signs of solder or of a wire having broken off of it. I can't see up the bottom of the microphone well enough to see what's going on on the bottom side of the transformer. I can sorta see the top of the transformer, but I can't really see any of the joints of the wires going in and out of the transformer. I'd like to remove it and get a look at everything disassembled, but I don't know that that is going to be an option because it's glued in there like cement. I suppose I could saw through it somehow if it came to that with serrated blade of some sort.
When I first got it, it made no sound. There was a wire in the middle chamber that had broken midway along it's length. I exposed clean wire and soldered them back together, and then the microphone picked up noise, but it sounds like a broken speaker where only the tweeter works kinda. No bass and kinda like a talkbox. It doesn't sound distorted. The signal is very very low, much lower than a 57 normally is.
Any ideas on what the deal is with this 4th wire? How to go about getting access to the joints on the transformer.
Is the link you posted saying that the orange wire does nothing. That it is just there if you want to change the impedance by replacing the red wire's position with the orange's?
Wow!! Was that 57 underwater for a while or did someone take a dump in it?
I like pictures. :)
No joke. That's what I wondered when I opened it up. IF I can figure out what's going on with the mic, and how to fix it, once I can get it working, I plan to do a thorough cleaning of it and replace a lot of the old dirty wires with new ones. Getting access to the joints on the transformer is still going to be the tricky part though.
P.S. If I am not using the correct lingo for electronics speak, correct me, I am a kindergartner when it comes to this stuff.
I am not an expert, but yes, that is what I got out of it...the orange wire is to change the impedance and is not needed to be hooked up.
