sproutrecording
I just upgraded from a pair of Behringer MX-8000's to a Mackie 24x8 with the 24E expander. Before the upgrade, I got no noise. Now, I am getting a hum that I can't for the life of me figure out. The power supplies and the power amp (samson servo) are racked in the same rack with nothing else. If the power amp is on and the power supplies for the consoles are off, I get no humming, but if I turn on the power supply to the consoles, then i get a lower-mid humming, even if all the levels on the console are at negative infinity and everything that can be muted is muted. When I racked the components I put electrical tape on the rack rails and covered the components sides in electrical tape, so I am fairly positive that I am not experiencing the side-effects of a ground-loop. Plus, I had used no electrical tape when I racked the power amp and the power supplies for the Behringers and I got no humming whatsoever with that. They are all plugged into the same circuit like they were before the upgrade. The only thing that has changed is that I am using Mackies and their power supplies instead of behringers and electrical tape on the rails.
Any ideas on what could be causing this and/or what I could do to fix it or find out what is causing it?
