Help on Acid (newbie)
  • Thread starter Thread starter mackovyak
M
mackovyak
Hi, I'm using Acid 1.0 d and Soundforge 4.5. I'm trying to lay down some deomo tracks. I record first the guitar track as a .wav and then a vocal or bass track the same way. When I add a second track into Acid, it's always at a faster teempo and I can't get them to be timed right. Do I have something set up wrong? I've tried uninstalling and reinstalling, same problem. Thanks in advance.
I'm sure the reason no one has answered your question is because there could be a lot of reasons why your tracks are not "lineing" (sp?) up.
Is the second track you're recording "live"?
Is the second track a sample?
Is it a "one shot".
Disk-based?
Loop?
Have you changed it's properties?
Have you stretched the "tempo"?
Etc...
Also...
It could be the fact that you are using Version 1.0. it might be a "CRACK". If that's the case then you will have to probably pay the price in terms of learning on your own. :(
If you expound a little bit more, in terms of what is specifically the problem, then I'm sure you'll get some more answers to your question.
:D
spin
