D
darkecho
Ok so I have a BG-1 from Mick, I am trying to make sure I set it up absolutely correctly for the best potential sound..
I have a Delta44 connected to my PC and want to attach the BG1 to the Delta44. The BG has XLR output and the Delta44 has all 1/4" Inputs. Do I need to get an XLR-TS cable for each of the BG1's outputs? Or do I need to use XLR-TRS.. the Delta can take balanced or unbalanced signals.
Once I get that setup and attach my mic to the BG1s XLR inputs in front, should I try to get the preamp to light up the green LED labeled "-3db" as long as it doesnt light up the Red "Over" LED?
How Should I adjust the knobs on the BG to get the optimal output to the computer? what should the computers meter read for DB? -18?
Also, should I set my Deltas software to -10 or +4?
