K
Kasey
I'm doing a recording of an upright piano in which the piano needs to play the role of a bass instrument. I've been told you can pick up a lot of the bass by micing the back of the piano but when i do that i mostly just get a lot of low mids that sound pretty bad. I have an AT4040 to close mic and two small diaphragm condensors i've been using as stereo room mics. or maybe i should be using the mics in different ways. I need a good bass sound out of the piano without a bunch of low-mids. can anyone help me out?
which mics to use and where to stick em'
thank you
thank you
. The removable front panel under the keys is the kickboard, not the soundboard as I originally mistakenly called it. Open that up to access the harp/strings. Behind the strings is the soundboard and the back of the piano.
