silencethevoice
I am posting this because I am basically at the end of my rope... I apologize in advance for the length of this post, but in 2 months I have tried everything under the sun to get this to work right, and am at a complete loss. Ever since I built this machine I have had a problem with sx 2 locking the system up. It is a hard lock up where the mouse cursor freezes, system has to be turned off or reset. The file I am using to recreate the problem is a 12 track stereo file at 24bit/96khz that has approximately 3 plugins per track (compression, exciters, etc.). CPU usage is at about 50%, disk at 0-1. This file recreates the problem everytime. It occurs somewhat randomly, but usually anywhere from 15 minutes to an hour into the looping of the entire file. But the problem is definitely not isolated solely to this file, it is a reoccurance in many other files, happens during recording, etc. The system is a dual Opteron 246(2ghz) with 2GB of RAM (corsair/kingston ecc reg, dual channel ddr), 3 hard drives: WD Raptor 36GB main system drive, 30GB Hitachi Ultra ATA recording drave, and 250GB WD SATA for additional storage, my display is a Matrox G450 Dual Video Card. I am running a M-Audio Delta 1010LT sound card with the latest drivers. I am running Cubase SX 2.2.039. I am currently running XP Professional with SP2, although I have done the majority of testing without SP2 installed, it was installed as a last resort. The system itself IS stable, I have run Prime95 for 24 hours straight with no crashes and also have run Soundforge looping with 4 or 5 plugins chained for 20 hours straight, just to isolate the problem to a Cubase related incident only.
Things I have tried:
1.) Disabled ACPI, and made sure all controllers, video, and sound were on separate IRQs.
2.) Changed DMA buffer sizes from 512 up to 2096.
3.) Tried removing all plugin inserts from my test file, and still crashes.
4.) Made sure no plugins were loading into cubase(moved VSTPlugins folder), still crashes.
5.) Tried running all diff. versions of SX 2 from 2.0 up to 2.2.0.39
6.) Changed Windows-> System-> Performance -> Settings to Optimized for Background, not performance.
7.) Changed Virtual Memory settings to 3000 min, 4000 max.
8.) Made sure I was set to M-Audio Delta ASIO in ASIO settings, not Multimedia ASIO.
9.) Various other minor things to optimize XP, mostly found on tweakxp.com...
If anyone has any advice, It would be GREATLY appreciated, I am really bummed, as I spent over 2 grand for this system, and have yet to get Cubase to run reliably.
Thanks in advance.
Thanks in advance.
