C
caddyboy0103
Did not know all caps was considered shouting, won't happen again. Actually I did not spend thousands of dollars on software that was a donation but it would have been a sin if i did spend the money. see i know that by calculating the amount of cycles in 1 sec i get the fundamental frequency. From there you multiply by 1,2,3 ect for the harmonic frequency(over tones), I guess what im asking is what would be the primary eq and how would i apply? Would i use a notch filter, would i use a bell, would i use a a low/high shelf or would i use a 5x Q? Also when i primary eq should i cut the odd harmonic frequency's or the even ones? Any help would be appreciated... also can some one tell me if this technique im looking for is FFT or DFT.
also how do you get the waveforms to look completely square like the pro's?
sorry for the multiple post my cpu frooze for a minute.
