D
DEL_P_O
Hi everyone.
I’m hoping someone will be able to help me. My laptop keeps crashing and going to a blue screen before switching itself off. It displays the error IRQL_NOT_LESS_OR_EQUAL
Here is my laptop spec:
Model: DEL XPX L720X
Processor: Intel® Core™ i7-2860QM CPU @ 2.50GHZ 2.50 GHZ
RAM: 8GB
System Type: 64-bit operating system
The laptop keeps crashing every time I use Cubase LE 5 Lite or Ableton Live 8.0.9 Lite with my Akai EIE Pro audio interface and my Akai MPK25 Midi Controller. This started to happen a while back when I bought the Akai EIE Pro and loaded the drivers. Sometimes it works fine and other times the sound just stops and I need to plug out the USB and plug it back in. Other times it crashes to this blue screen which says among other things “IRQL_NOT_LESS_OR_EQUAL” before shutting down my PC. It’s gotten worse now that I have both the audio interface and midi controller plugged into my Laptop via the USB Ports.
I downloaded an app called WhoCrashed which looks at the number of times my Laptop has crashed and what the possible root causes are. They all lead to a USB 3.0 related driver called nusb3xhc.sys
Please see the output from WhoCrashed
Can anyone help? Has anyone seen this issue before? It is preventing me from recording on my Laptop.
Any help is much appreciated.
Thanks
Mick
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Sun 03/02/2013 23:28:49 GMT your computer crashed
crash dump file: C:\Windows\Minidump\020313-22261-01.dmp
This was probably caused by the following module: nusb3xhc.sys (0xFFFFF880063BE2E7)
Bugcheck code: 0xD1 (0x2C, 0x2, 0x0, 0xFFFFF880063BE2E7)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\drivers\nusb3xhc.sys
product: USB 3.0 Device Driver
company: Renesas Electronics Corporation
description: USB 3.0 Host Controller Driver
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nusb3xhc.sys (USB 3.0 Host Controller Driver, Renesas Electronics Corporation).
Google query: Renesas Electronics Corporation DRIVER_IRQL_NOT_LESS_OR_EQUAL
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: nusb3xhc.sys (nusb3xhc+0xE2E7)
On Sun 03/02/2013 23:02:00 GMT your computer crashed
crash dump file: C:\Windows\Minidump\020313-44834-01.dmp
This was probably caused by the following module: nusb3xhc.sys (0xFFFFF880063B92E7)
Bugcheck code: 0xD1 (0x2C, 0x2, 0x0, 0xFFFFF880063B92E7)
On Sun 03/02/2013 20:53:09 GMT your computer crashed
crash dump file: C:\Windows\Minidump\020313-42775-01.dmp
This was probably caused by the following module: nusb3xhc.sys (0xFFFFF8800580E2E7)
Bugcheck code: 0xD1 (0x2C, 0x2, 0x0, 0xFFFFF8800580E2E7)
RAM: 8GB
Thanks
Mick
