Shack
Help! Can anyone please tell me how to connect inserts? I want to connect a track/channel to an external compressor to use for mixdown.
My mixer (Tascam DM24) has got insert jacks on each channel and so I connected the one on the vocal track to the compressor but zilch is going on. There is no singal coming through.
I am new to using inserts and assumed I only had to use a Y cable with the split ends of the Y going into the compressor. It appears, obviously, that there is more to it than that.
FYI if it helps, the channel I want to connect the compressor to is being used as a return from tape.
