M
mada
OK, let me give you a little background information before I get into the problem at hand. My system:
AMD Athlon 1GHz
ABIT KT7a-RAID with a VIA chipset
512 MB RAM
4gig 5400 RPM for apps
30gig 7200 RPM for audio
Win2k pro
N-track
Delta 44
I was having the common problem that VIA mobos have of clicks/pops/crackle during playback, and after searching the net and trying everything suggested, I finally found something that worked. I disabled ACPI. I did this in device manager by updating the drivers to "Standard PC". After restarting, I had to reload all my drivers, including the MoBo, video, and delta drivers. I did some tests in n-track and everything worked and sounded great. I came back a couple of days later and my system would not bootup. It got stuck at the white Win2k startup screen. So, I reloaded ACPI, in safe mode, and it booted up right away. I figured that disabling ACPI the way I did caused my system to not bootup, so I reinstalled win2k as a standard computer. Again, everything worked perfectly. I even shutdown the computer and restarted and it booted up fine. But, the same thing happened a couple days later. I tried to boot up and it stalls at that same screen. Does anyone know why this is?
I'd appreciate any help with this. I've been trying to get my studio up and running for a while now, but it seems like there are an endless amount of little problems. If you need any more information just ask.
Thanks in advance,
Adam
AMD Athlon 1GHz
512 MB RAM
Win2k pro
N-track
Delta 44
Thanks in advance,
Adam
