N
notsirk
Hello!
My goal is to be able to play directly through my computer (for reduced volume) and record with good quality sound. My problem is that I can't get a clean sound without a bunch of added distortion.
First I was using a mini mixer and running that through an Audigy2 ZS sound card which gave my a good recorded sound but what came through the speakers sounded terrible. I also read that Soundblaster cards aren't good because they resample down to 44.1khz. Also, I want to be able to record multiple tracks at once.
I upgraded to an external interface, the Lexicon Omega (USB 2.0), but I don't get a clean sound through the speakers (which are Alesis powered studio monitors) or a clean recorded sound. This only samples up to 48khz.
I tried the E-MU 0202 USb 2.0 which samples up to 192khz but it did was not compatible with Adobe Audition 2.0 and lacked some features I'd like to have.
My roommate has the Eridol UA-25 which sounds the best I've heard except for a high pitched squeal. My roomie gets around it by running through a Fostex digital multi track, through an optical cable, through to his computer. I don't know what the recording quality is through the Eridol because we don't have the drivers.
Does anyone have any suggestions or similar experiences that you have found a solution for? Any help would be greatly appreciated before I spend any more money.
Oh, and I'm running a PC with 2.5 gigs RAM if that helps.
