Help cables...
  • Thread starter Thread starter Theory
T
Theory
So i bought everything but i think i got the wrong cables but uhm jus to make sure tell me which type i need..i feel so stupid right now this is what I have
RNP - RNC - RME Multiface
do i need a y cable for it? Thanks in advance for the help!
I suspect you are asking if you need a Y-cable to connect the RNC to the RNP. It depends on whether the RNP uses two TS jacks or one TRS jack to connect insert effects.
I just did a web search and it appears that the RNP does use TRS jacks for inserts, so you need two Y-cables, one for each pre-amp channel.
