ok
Only if the audiophile is isolated with OC703 filled enclosure, and protools is diffused with a QRD...unless of course your room is square. Then all bets are off. In that case, place your engineering position dead center in the room and insert a Graphic EQ in the signal path. Oh, one other thing..paint the room in fluorescent green...protools likes fluorescent green. Of course though, its a well known fact that audiophile doesn't like fluorescent colored rooms, so you will have to get its permission first. Wear a garlic bulb on a chain when you ask though. Audiophile LOVES garlic.
Also, you will have to download the driver:
C:\WINDOWS\system32\DRIVERS\audphl\fluor=grn\accept.sys
