rayc
retroreprobate
Hello Folks,
I'm almost finished a new collaboration project and when I sat down to update a mix I turned on my DELL Inspiron 530 & the screen stayed blank while the machine seems to try to boot in 5 second cycles. No beeps and an amber light at font power button. If I disconnect it from the power by pulling the power cord out & then, after a minute, reinster it - it just continues the cycle. The same thing happned when I turned off the power at the wall & left it for 2 days.
If I hold in the power button at the fron the cycling will stoip but nothing else happens.
I backed up a week ago. Hope fully I'll be able to use that back up if all goes belly up.
Can anyone help?
The machine is ONLY used as a DAW & is like new. Very few programs are installed & all that are on it are audio/video related.
HELPPPPPPPPPPPPPPPPPPPPPPPP!
I cracked open the case to reseat the RAM & vid acrd (can't do one of the RAM cards properly beacsue the vid card is IN THE WAY & won't come out without being dragged across the RAM.
Anyway, where was I? Oh, the fans run - no boot up - just the fans cycling on & off with the power. Orange light on the motherboard is on when the power is connected & the thing is "on".
Can anyone help?
