SM Pro Audio XPM1 Single Mic Preamp Features:
-Input Impedance: Mic-600 ohms / Line-10K ohms
-Max output level: +14 dB
-Input connectors: 1/4” stereo TRS and XLR
-Phantom Power: +12VDC
-Max input level: +22 dB
-S/N ratio: >105dB
-Max Gain: +50 dB
-Frequency Response: +0/-1dB 20Hz-20 KHz
-Output impedance: 100 ohms
-Power: 12-18V DC adapter (optional accessory, not included)
-Output connectors: 1/8” stereo TRS and RCA
-Size: 88 X 54 X 38 mm
MXL V67G
Large Capsule Condenser Microphone
Description
Technical Specs
Type:
Pressure gradient condenser mic
Diaphragm:
6 micron gold-sputtered
Capsule Size:
32mm/1.26in.
Frequency Response:
30Hz - 20kHz
Polar pattern:
Cardioid
Sensitivity:
15 mV/Pa
Impedance:
200 ohms
Output:
Transformer-balanced
Equivalent noise:
20 dB (A-weighted IEC 268-4)
S/N Ratio:
74 dB (Ref. 1 PA A-weighted)
Max SPL for .5% THD:
130 dB
Power Requirements:
Phantom Power 48V (+/- 4V)
Size:
47 mm x 184 mm/1.85 in. x 7.24 in.
Weight:
1.3 lbs/589.67g
Metal Finish:
Green with gold grill
so this is it right? the reason it doesnt working, nothing broken right ?
