G
goodshipp
I'm curious......
Rank packaged drum kits (not counting cymbals) within each major brand:
Obviously, certain kits are entry level, and certain kits are professional grade, what about the in-betweeners?
So, Rank 'Em from worst to best by brand. What's the best shell pack from Pearl, Tama, etc.?? What's the worst? What are the most important qualities of a good set of drums?
) ...then heavier, more expensive double-braced hardware might be appropriate. The double bracing really does little for the durability or capacity of the stand, but lowers the center of gravity which is a useful counterbalance when dealing with very high and heavy loads. If however, you play like the vast majority of post-Nirvana drummers, lighter and less expensive hardware is perfectly functional...assuming the only difference is the bracing. Section length, wall-thickness and tilter quality are also important.
