dainbramage
Hey guys,
As mentioned in earlier threads, I am on the verge of buying an RME Fireface UFX which have two unbalanced headphone outputs. Quote from the manual:
"These low impedance outputs of highest quality are able to drive headphones at
higher levels undistorted, no matter if low or high impedance headphones are used." (page 9)
So far so good. I am thinking about ordering a pair of Sennheiser HD 650 headphones with the Fireface. Their nominal impedance is @ 300ohm and the ones on the Fireface are only 30 ohm.
Quote from RME forum: "The Babyface provides 30 Ohm on the headphone outs. This could be indeed a problem with high ohm headphones." (from an administrator user)
It should be mentioned that the UFX headphone outputs have two options: high (+13dBu) and low (+2dBV) while the Babyface only has a low option.
Anyway because of this I figured I'd need a headphone amp but then I read this at another forum:
It's in the manual, it's 30 ohm, so way more than capable of handling any of those headphones. It was referring to a question on using 300 ohm headphones as well.
Is there some odd connection between output and input impedance that I'm not getting? Do they have to correlate? Or can I safely order the previously mentioned headphones along with the UFX?
