E
EasyKill
My band is currently in the process of recording songs to get an EP of some sort out there. I want to preserve band chemistry and live energy, so the way I want to do this is to have us record live together with all of the separate components in different rooms to cut down on mic bleed. I would possibly overdub vocals and lead parts later, but I want to have the live, energetic core as the basis of it all. I'm using an analog mixer for all of this. My question is, what is the best way for all of us to have headphones as monitors while we play? The best way I could figure out how to do it was by plugging the headphones into the aux sends so that I could mix however much of each signal each member wanted to each set of cans, but using the aux sends causes sounds to only come from one side of the headphones. The other method I used was to just route the channels to the main mix and use the standard stereo headphone output, but that way I'm not able to mix the levels of each signal to each members liking. Is there a better way to do this? Or a way I can convert the signal from the mono sends into stereo for the headphones? Thanks guys.
