Pins 1, 7 & 8 are not connected. Looks like the supply voltage is +6VDC. There are, naturally, two 386D chips, one for each headphone channel, both configured the same:
Pin 1: not connected
Pin 2: input (from headphone level pot [which is on a different PCB] via 1Kohm resistor and then a 3.3uF/50V cap)
Pin 3: 0V
Pin 4: 0V
Pin 5: to pins 3 & 4 via 10,000pF ceramic disc cap and a 4.7ohm resistor; to headphone jack via 1000uF/10V and a 1ohm resistor (this trace is also again at this point, coupled to pins 3 & 4 via a 10Kohm resistor)
Pin 6: +6VDC
Pin 7: not connected
Pin 8: not connected
There are some suspicious looking solder joints in all this, and I'm curious as to why the shield for the R channel is not connected to the level pot ground (it is floating), while the left channel is...both connect to ground at the other end on the PCB with the 386D chips...wondering what might happen if I duplicated the L channel's ground connections in the R channel...hmmm...though it looks like the L channel is linked to a couple transistors that make their way to the talkback mic and the R channel does not...maybe I shouldn't mess with that...
