DP01 So Far...
This is really my second weekend of recording with it and so far so good. First off all I have to record with at this point is an acoustic guitar, a drum machine is the next purchase. With that said, I have had no problems assigning tracks for recording or assigning the effects to a or b. Of course I have experience with multi-track recording so maybe that makes the difference.
One draw back for somebody wanting to record 2 tracks at once is the effects can only be assigned to one input at a time, but if you just working by yourself this is not a problem.
One thing I am not understanding with the effects is, you have control over the parameter, and the volume for the effect. The volume is a curious thing as at first I was trying to use the volume as a "mix" variable, ie, wet to dry ratio. I doesn't work that way, it is actually effects gain, and with it turned down, your input signal goes down as well. I am not understanding why the effects volume operates this way, to me it doesn't make any sense. Maybe somebody can shed some light as why it would be set up this way.
One other thing that I have noted, as I have had the problem happen twice now is powering up the unit. Two times at power up it seems to just get "hung". The screen won't display anything, it just faintly shows the LCD boxes, no letters or numbers, just the boxes themselves. I have had to turn it off let it reset and turn it back on very slowly for it to initialize. If this keeps up I will have to take her back and get it exchanged.
I read on another post, about the DP being limited. Yes as compared to larger set ups, and DAWs it is. But for the market it is intended for and the price paid it its one hell of a unit in my opinion. With outboard effects and a mixer, this unit could be used to produce some mighty fine sounding music. Here again, you just have to work around the limitations.
I have gone all the way through the process, recording mixing down to 2 track saved as a wave file in the FAT partition, hooked up the usb port and uploaded to the computer. One note on that process that is not real clear in the manual once you have mixed down the tracks to stereo L and R, you must save the "master". In the manual you jump from page 24 to page 45 to accomplish process. If you do not save the master you have completed and move on to the next master the previous master is overwritten. The manual is not real clear at least to me anyway on this process. Of course it could just me, ADHD is no fun folks!
Well I guess thats about it at this point. Today, I have a lead track to add to the song I am working on, and I have a finger picking song I am want to get tracked as well. Then it's mixdown time!
Until Then,
Straight Ahead!
