Thanks
I listened to Stand Up Wendy. I really liked the raunchy verbed out guitar sound.
Thanks again. When I play live, I only ever use a slight 'slap back' echo on my guitar so I do like to play around and experiment with the sound and adding stuff when I'm recording. Sometimes it works and sometimes not so much.
Not too crazy about the drums though. They have this thin, crisp polite sort of sound to them that doesn't seem to suit the song so well, you know?
Yes, I agree. Laziness on my part.
The drum loops were simply the ones that came ready installed on the Yamaha AW16g. I just laid down the drum track as it was and wrote the song around the beat (it was close enough for the kind of rythm I had in my head, though far from perfect).
The vocals seem pretty well performed, but I'm hearing a lot of sibilance.
I use an AKG C3000 with a pop filter but get in real close (see below for my thoughts on sibilant frequencies).
Actually, the whole mix seems to suffer from an overabundance of whatever frequencies contain the cymbals and the "S"s in the vocal track.
This is one of the problems I seem to have over and over and it would be great to learn how to 'fix' it (I mean apart from someone telling to ease off on the 2k and above frequencies
Relating it directly to this recording, the problem I have is that I wrote and recorded the song in one evening and then immediately started work on mixing. I then spent nearly two days constantly listening to it and tweaking it. Now I know that human ears go a bit 'foggy' after long exposure to loud music and I think that what happens is that as I'm tweaking and trying stuff, over time my ears go dull and I just keep edging the 2k up a bit because it seems to make the recording clearer.
Then of course when I think I've finished it, it's got too much and after I've left the track for a week I'll return to it and be able to hear it's a bit thin and harsh for myself.
So now I can clearly hear that what is supposed to be a crash cymbal sounds more like a "pshhhhhhh" noise not dissimilar to the sound Bowie used on Sound & Vision.
Good job though, and I really like that guitar sound that I don't hear too much anymore.
Well your feedback is appreciated thanks.
When I record at home, it's done as a way of just getting something that sounds half right so that I can play it for the band to see if they are interested in adding it to our set (and because I love making music). But it would be great to be able to improve my recordings and add that little bit extra to make them better.
The guitar is a Gretsch 6120, double tracked with distortion on the main (slightly off center) signal and then the second signal is the one dripping in very wide and slightly out of phase reverb, which is set at center so it's actually also out of line in the stereo spectrum with the original signal.
