D
DNAInstant
I'm seeking help on how to use the gear that I have had sitting around for years effectively to actually make music. Here is a list of my gear:
Here's my current workflow:
As you can see, I've thought about this and researched quite a bit over the years. I will post some sound clips as soon as possible. I am getting way too much mush in my tone and none of the guitar notes are distinguishable from one another. I've tried rolling back the gain on my amps, moving around the mic, etc, but none of this seems to help. The sounds I am getting from my amp are simply not being translated effectively at all into recording, and simply layering even just 2 guitar tracks would I think result in an incomprehensible mess.
Now, I would like to shoot for a simple underground metal sound similar to this: https://www.youtube.com/watch?v=WbRhnCBHab0. Absolutely nothing fancy going on there, production wise (shouldn't be hard to do). One caveat is that I have to record at lower volumes, can't be blasting anything too loud, I would like to keep the amp at around a 2 maximum. Realistically, do I need to build an isolation cabinet to do what I want to do? I honestly don't know, but it is a project I am willing to undertake. Basically it's time to start taking my music a little bit more seriously, frankly.
- 24 Fret PRS SE Guitar (basic Humbucking guitar, I think the pickups sound nice)
- Fender Superchamp X2 (Tube pre-amp to digital modeling)
- 2 Shure SM57s. (Been told to only use one to start out with before incorporating anything else).
- Mackie Onyx Blackjack (Pre-Amp with two 1/4"/XLR input/outputs, headphone input)
- Modern Windows 7 PC with Reaper, Audacity, EZDrummer, and many amp simulator programs.
- Been playing guitar (a lot) for 7 years.
- Plug in all equipment, dial in tone on amp. Then roll back distortion 2-3 notches from where I was.
- Position one SM57 about 1 inch away from slightly off center of the cone of my guitar amp.
- Find the amount of gain for the pre-amp to give an input signal which is just below going "into the red" on Reaper. Usually this is around 35-40 decibels(!?).
- Create click-track in Reaper. Practice tune/riff/whatever a few times, work out what I want to record.
- Attempt an actual take as cleanly as possible.
- Go back and listen to the take -- if sloppy or inaccurate, try again. (<--- one thing I would like to do here is simply play multiple times on repeat until I get a take that I think sounded good, since this is a lot more efficient than having to hit stop/delete/record every time, but I don't know how to do this).
- Usually takes me about 30 minutes to get to this point. Which is a lot, which shows I am a newbie.
