Hard drive space and preamps on vf160
  • Thread starter Thread starter Herm
Herm
Herm
I have been thinking of buying a vf160 for live use and can get by just fine with 8 tracks.
My question is does the amout of time you can record double if
you only use 8 tracks instead of 16? I hope that makes sense.
I didnt want to get into swapping harddrives for more time if possibe. I would like to be able to record a 4 hour gig.
Also will the 1/4 inch inputs work well with mics like sm57,s
on guitar amps or will I still need an external preamp of some kind
for that?
Thanks for the Help.
The VF160 with it's 20 Gig HD gives almost 8 hours of record time using 8 Tracks. (472 minutes)
You will need Mic Pres or a mixer with Channel inserts on the mic channels to record with mics.
CR ><>
Its possible without preamps
Well I record directly with a Sure sm58 without using a preamp.
For vocals you have to turn up the input gain knob very high in order to get a hot signal, but it does work. I would have thought for micing up a guitar cab it should work fine as the signal is likely to be much louder than the human voice.
I believe you can buy an attachment to turn the vf160 from an 8 to a 16 track simultaneous recorder, but its not something I need so haven't bothered.
Vf160 does have 8 mic preamps but only two of them have XLR jacks and phantom power that can accept both dynamic and condenser mics while the remaining six has only 1/4" jacks so you'll need a suitable adapter or a mic cable with a 1/4" plug on the other end to connect a dynamic mic into those inputs.
If you didn't get a hot signal even with the gain knob at max then you'd need another preamp in front of the built-in one but if you get a hot signal by turning up the gain then the mic pre is doing it's job just fine.
