Half Rack Screw Size
  • Thread starter Thread starter lunatic
L
lunatic
Member
What is the screw size required to attach half rack devices (i.e. DMP2, Roland JV-1010) to a universal rack shelf? My DMP2s didn't come with one!
Thanks!
Lunatic
Personally I don't know the size,however,I use standard 19"
rack SHELVES for un-rackable equipment.
Well, the DMP2s are made to be mounted on a 19" shelf but what do I secure the DMP2 with? There is a hole in the bottom of the DMP2 (as is on my JV-1010) for attaching to a universal shelf but I just don't know what screw size to use :(
Thanks anyway...
Start off with standard rack screws and take it from there.
If you can't fix it with duct tape, get something you can.
I don't think there is a standard for that type of screw, but finding the right one is simple. You go to a hardware store with the object in question, and you find a screw with a size that seems to fit, and the you GENTLY try to screw it into the hole. It should go in easily, with a nice fit, but requiring no force.
When it comes to Japanese equipment I'd try the metric sizes first.
The few pieces I have used have required 8-32 and 10-32. 8-32 is probably pretty common, but Regebro is right about the Japanese gear: assume metric. If you use a screw, make sure that you use the shortest possible length: in some products, the PCB does *not* have a clearance hole for the mount screw, and using a too-long screw can short PCB traces to the case. Not good.
The universal rack shelves and half-rack units never seem to have countersunk holes to allow a mounting screw head to sit flush, so even a flathead screw will make the screw/shelf/unit stack too tall to fit into a true single space, and will hang up on the gear below. Another issue is that half-rack pieces usually have only a single center hole, which means that they can rotate a bit on the screw, causing it to loosen over time. With all those hassles, I just gave up. I use 3M's thin doublesided foam mounting tape, and just stick them down on a nice cheap blank shelf. Usually, Velcro will also make the stack too tall. If I need to move them, I just peel them up...
