rogga_bogga said:
Joe Satriani has this trick that he calls "Lizard down the throat" ...pick a note on one of the lowest frets and then slide up. And now the trick...push down your whammy bar as you slide so the note stays the same. If you do it pretty slow and accurate it sounds pretty weird. You get the sound of a finger sliding on frets but only one single note.
One of my all-time fav's!
Another good one, a la "Hordes of Locusts" : do pull-offs with your left hand on the low E string, say from fret 8 to 7 to 5 , repeatedly. While doing this, lightly touch the string with your right hand palm and run it up and downt the string. With distortion you will get all kinds of harmonics that sound like computer talk or something. EVH does this in many songs too.
Other EVH noises: push a sting down with your right hand until it actually touches a pickup pole an then let it back up. Kind of a "pop/ boink" sound. (from Romeo's Delight)
With your pick, scrape the trem springs in the back of the guitar. Sounds great with thick flanging. (Cradle will Rock)
Strum the strings behind the nut. (Runnin' with the Devil)
Rub all the strings
really hard with your right palm. (Atomic Punk)
Play your guitar like a slap bass (Mean Streets intro)
Turn down your volume. Hit a chord or a single note. While the note rings, turn up your volume. Repeat as needed to produce cool, ethereal notes with no attack. (Cathedral)
This next trick only works with a Floyd Rose bar: hit a note and dive the bar (not too much). Now, instead of smoothly bringing it back up, just let go and let it snap back into place. Zing!
Or how about another JS trick that only works with a reel to reel tape deck: Arm a track for recording. Play a note on teh guitar. While the note is sustaining, hit the record button. You will only hear the effect when you play back the tape: the notes starts out insanely high and quickly warbles down to pitch (I Just Can't Slow Down)
I could go on and on......
Aaron
http://www.voodoovibe.com
