Guitar tracks pro
  • Thread starter Thread starter guitarjesus
G
guitarjesus
Has anyone used this software?
It looks like it will work with my set up.
Dell 400
384MB SDRAM
Windows 98
It looks like it has drum loops.
Does it have bass samples?
Not many member on the board use it :) I dunno much, I heard alot of good thing about GT Pro, but the backward is, it's not that MIDI friendly. It's good if you just do audio (guitar) work IMHO.
Jaymz
It doesn't have bass samples, but it does have some drum samples. It also comes with an old demo version of Fruity Loops, that I have yet to figure out how to use, since the manual isn't available any more.
So far I'm pretty happy with it. I've found the interface pretty intuitive, and easy to migrate to from my Tascam 424.
I have Guitar Tracks Pro, and while it is a pretty good program for a hundred bucks, it has some "issues", particularly in the area of soundcard driver compatibility.
GTPro uses MME drivers, while it can get by with WDM drivers, it will access them in MME mode, what this means for most people is that although cakewalk tout GTPro's ability to work at 24 bit, most WDM drivers when accessed as MME will only support 16 bit performance.
If you are running win2000/XP your soundcard most likely uses WDM drivers.
GTPro allows you to use up to 16 real-time effects at once, and will only allow a maximum of 3 effects per track or aux, and only 2 on a main bus, this is actually a very limiting factor, especialy concerning the main bus.
I use Sonar 2.2 XL as my main setup, and now that cakewalk have seriously updated Home Studio 2004 to be very much like Sonar "lite" I will probably be getting that to use on my laptop.
The XL version of HS2004 has all the effects in GTPro except for the Revalver SE amp sim(which I never use anyway), and will allow up to 24 real-time effects at once, without the track/bus limitations, this is pretty important for me. It can use MME, WDM, and ASIO drivers, and should be able to give you "no bullshit" 24 bit recording under win2000/XP. And like Sonar it can be setup with up to 16 aux busses instead of GTPro's 2, I usually run 4 aux busses.
After taking a good look at HS2004 XL, it is IMO well worth the extra money when compared to GTPro.
moskus said:
Does GT Pro have Input Monitoring?
No, due to the MME driver limitation it only works at higher latencies, and while input monitoring is a nice enough feature in Sonar, and I'm not sure if the new HS2004 has it, but regardless, once I have more than a few tracks with real-time effects to playback I can't use it anyway, I use a mixer and an outboard reverb unit to monitor wet while tracking dry.
So what you were saying in the WDM/MME-driver section above was that:
- GT Pro uses only MME drivers
- All soundcards (for Windows) have MME-drivers. If you have WDM-drivers, you also have MME, because they're included.
Now I get it! I was a little bit confused... ;)
I don't think it's that you actually have MME drivers, it's more that a WDM driver can be accessed in MME mode, and for most WDM drivers this will mean both higher latency, and a limit of 16 bit performance.
I have an Edirol UA-20 2x2 USB audio interface for my laptop, and it comes with a WDM driver for low latency 24 bit recording in a program that supports it, like Sonar, and also an MME driver (designed for win2000/XP that will give you 24 bit performance, but according to the manual, you can only have one of these drivers installed, so you would have to choose one depending on your recording program's driver compatibility.
The driver limitations of GTPro were one of the main reasons that I bought Sonar 2, I was upgrading to win2000 professional and wanted a program that was compatible with WDM drivers, not to mention the per project file folders, it IS so nice to be able to keep tabs on exactly where all the audio is for any given project, GTPro uses the old cakewalk system where all you audio files are placed into a single folder, and they have the most cryptic names.. you really have no idea what is what in there.
