Guitar Tracks Pro at 24Bit ? NOT!!
  • Thread starter Thread starter Pier Calacino
P
Pier Calacino
Hello all,
Does anyone know what I have to do to enable 24Bit in GT Pro? I try to change the settings but it defaults back to 16Bit.
I am using an Audiophile 24/96 card and Win2K OS.
Is it a Driver issue ? and if so, what do I need to do to resolve this issue?
Thanks
Pier
Not familiar with GT Pro, but I suspect it is similar to Sonar.
In Sonar there are two bit depth settings: Audio Driver and File Bit Depth. Are you changing both settings and then reprofiling your sound card after the change?
After that, you should exit and re-enter the program. Hopefully that will work for you.
Hi dachay2tnr,
I did not change both, I will give that a try and see what happens.
Thanks
Pier
Hello all,
This may be helpful to some.
I received a reply from cakewalk regarding my problem, and this is what they said.
:Try downloading some MME drivers from www.midiman.com GT Pro cannot record in 24bit using some WDM drivers. Delete GP2AUDDX.INI from the GT folder once you've done so:
Pier
