Guitar Rig LE via Cubase - Can't get Guitar to sound
  • Thread starter Thread starter neo31111
N
neo31111
Hi,
Really hoping someone can help. Just purchased NI Audio Kontrol 1 which comes with Cubase LE and Guitar Rig LE, have everything working except the fact that i cannot record guitar into an audio track in Cubase. I can record the tapedeck loop into the Audio Track but when played back it is only high level hissing. I do see activity on Audio Kontrol INput 2 (green light displayed everytime i strum the guitar), line 2 is INST and gain is up, yet i do not see Guitar Rig LE software see any incoming input (on the top where you see input and output levels in Guitar Rig LE).
I've read a ton of posts and can't find out what I'm doing wrong. I've got the vst for GR LE installed to the directory for Cubase VST's, so i know that's not it. In Cubaase device setup i have ASIO DirectX Full Duplex selected for the VST Audio System - and ALL other VST's (battery, Kontakt, ect) work without a problem, can record and hear. I do notice that i have the option of choosing Audio Kontrol 1 as my VST Audio System, and have played with those setting only to find that when i choose that, 1. - i can no longer hear any output from keyboard or tracks that have already been recorded, 2. - the "input" section of Guitar Rig LE shows activity where previously it did not, however i still can't hear any guitar sounds or tapedeck, ect..
Can someone PLEASE help me as I'd really like to get the guitar rig le working within cubase le. Thanks in advance for any help it is MUCH appreciated. /Nate
You need to instal the drivers for your interface, WHen thats done and your unit is connected and powered on you should be able to see the drivers in the device setup window of cubase and select that. (The same place you slected "ASIO DirectX". After that you need to select which ins and outs you want in the "VST Connections" Window, You can find that on the "Devices" menu.
One more thing, after your ins and outs are set up you need to set which input you want to record on the track you're recording on. Hit the monitor button (little round button with a speaker) to set your level.
