philbagg
Just Killing Time
Hi guys, long time no see!
I'm having an issue with my RGA 121 Prestige at the moment. Whenever I plug the cable in all the way, there's no signal (well, there's the very faintest sound - barely audible below all the noise).
When I pull the cable out a small bit, I get full signal. I've replaced the input jack and the connections are solid. I've tried 4 different cables, different amps, pedals, the lot. Still the same issue.
There are 3 wires connected to the input jack, which I'd imagine are signal (tip), ground (sleeve), and the battery. My guess is that when the tip makes a connection, I get signal. But when the ground connects, the signal drops. If I'm right, is there an internal problem with the grounding of the guitar?
Thanks in advance!
Thanks in advance!
