Kingofpain678
Returned from the dead
hi everyone! im hoping someone can help me out with this problem that i have.
when tracking guitars i get a big booming sound when i play C, C#, and D notes especially when i palm mute. im using a dean vendetta guitar made of paulownia. im playing the a line 6 head into a marshall 4x12 closed back cab and my signal chain is this:
Amp -> Mic -> Mixing Board -> interface.
i have also tried putting a compressor and 31 band EQ inbetween my mixing board and interface. the compressor didnt limit the booming frequencies like i thought it would. the eq kind of worked but i would rather not have to track guitars that are very heavily EQ'd, i would rather fix this problem at its source. i will post two .wav files later on in the post to show the difference between the unprocessed track and the EQ'd track. also, i will upload a picture showing the dimensions of the room i am monitoring the tracks in.
i have tried putting my speaker cab in many different areas in my monitoring room as well as outside of my room in a big open basement and still the problem persists. also, i have tried MANY different amps. i have also tried using many different microphones and mic placements to no avail. i found this site which shows someone seeming to have a problem similar to mine, which turns out to be due to his guitar.
another member on this site took a listen to the .wav tracks i had mentioned earlier:
Unprocessed
Processed
he said "I loaded it into reaper, then used a parametric EQ to find the booming frequency. I agree that it has a pronounced boominess at about 122 Hz."
the processed file was processed using a 31 band EQ. there is a 10Db cut on 20hz through 125hz and 10khz through 20khz. and a 4db cut on 160hz 800hz and 8khz. the file shows first a riff in C. next it shows C, C#, and D notes. and last it shows some other random notes that have no boominess at all. and youll notice that even the processed track still has quite a bit of boominess in it.
so now that EVERY bit of information is available, here is my question: what could be causing the boominess? is it my guitar or could it possibly be that my untreated room is emphasizing bass frequencies? what are some options for dealing with this problem?
a very special thanks in advance for anyone who can even get through reading this post
Unprocessed
Processed
