grounded electric
  • Thread starter Thread starter xcrazymx
X
xcrazymx
i just moved to a new apartment and found that the electric is not grounded. i'm hearing a buzz in some of my equipment and was wondering if there's an easy solution. i've already talked to an electrician who said grounding the building was going to be a difficult job.
One easy way to Get the Building Grounded is to Report it to the State Building Inspector and he will force the Owner to Ground the Buildings Power as Non grounded Outlets can be Dangerous and are against the Building Codes of most Civilized Countries.....
Another way if you want to do it yourself is To hang a Wire with a Nail on the End off of your Balcony and Hammer the Nail into the Ground and connect the Other end of the Wire to the Ground Plug on the Power Bar you use for your audio equipment which should Ground the Power bar...It sounds Very Mickey mouse but is an easy way to do it......
It"s Gotta suck trying to record when everything has that Bad Humm in the Backround!!
Cheers
unfortunately, i did some research and found that the housing code in philadelphia does not require grounded electricity, with the exception of a washer and dryer. i may have to try the second option. thanks for the post!
Cheers
Well I guess Philidelphia isn"t a Civilized Country!!!...LOL :p
