		stevieb
Just another guy, really.
All pictured on this webpage:
http://www.theelectronicsshop.co.uk/Accessories/levelcontrols.htm
3 each, Order code 962-110
2 each, Order code 962-150
5 each, Order code 962-250
8 each, Order code 962-160
I see they range from 15 to 100 watts power handling capabilities, and all have Impedance of 8Ω ±20% and Attenuation- 0dB to ∞dB
Most are NOS- the 962-160's are all made in Japan, the others apparently ROK.
I know they are sold to, say, be mounted on the wall of a room and adjust the volume of speakers in that room (without having to go to the source,) and this http://www.colomar.com/Shavano/lpad.html talks about using them for tweeters and mids- are there any other uses for them?
I would love to have a 5-25 watt guitar amp attenuator,- the kind that drives power tubes hard so you get power-tube distortion- can I use them to build those attenuators? This guy http://www.regiscoyne.com/ampwell/ apparently did- anybody use such an attenuator? And this guy http://www.amptone.com/wallmountspeakerattenuator.htm went super-simple, just mounting an L-pad to the bottom of his amp. Is this an example of lunacy, or elegant simplicity? (I know there is some yahoo who is selling "attenuators" on ebay for about twenty bucks- they are NOT real attenuators, but rather, as best I can tell, master volume controls that you plug into an amp's effects loop. Yuck.)
Anybody have any use for any of them?
I just read this about L-Pads:
3.4 "L-Pads"
The "L-pad" is a resistive device with two variable impedance pads. It has constant impedance with respect to the amplifier, usually 8 or 16 ohms. "L-pads" were developed to control the output level of tweeters and midrange speakers without the high current typical of woofers. The "L-Pad" sounds great, has minimal phase shift, is very linear up to its power rating but has a major drawback, which virtually eliminates the “L-Pad” from use in multi-room and custom installation situations. Because the "L-pad" is a constant impedance device, at lower volume settings the "L-pad" converts
all of the energy not sent to the speakers into heat which can be considerable. Even in a moderately powered system, "L-pad" reliability is low and lifetime is short. Worse yet, there is a fire hazard present when using "L-pads" to control full range speaker level signals.
http://www.knollsystems.com/tech-docs/whitepap.pdf
That does not sound good in general, and seems to bode badly for my guitar amp attenuator idea.. But wait, they are used to "control the output level of tweeters and midrange speakers without the high current typical of woofers," so they don't have those drawbacks in those applications?
On a related note, isn't a "speaker motor" just a speaker with no cone, thus it produces no sound? THIS guy http://amps.zugster.net/articles/attenuation says it is...
3.4 "L-Pads"
