GONZO-X
Eminence Legend 122
it's 16 ohms, 35 watts capacity, with a 6 oz. magnet.
well, the idea behind this is....
my Celestion vintage 30 (a 60 watt driver) is well matched for my boogie at max volume, but not for the small volumes i'm having to record at now.... in the house...
and inside the demeter isolation cabinet i have, the vintage 30 has a midrange i do not like-
as if i'm not pushing the speaker hard enough to get the full range of sound out of it..
so, this new speaker is an experiment....
take a low watt speaker, with a tiny voice coil, carefully dial in the power section on the boogie, possibly add a THD Hotplate (or 'future' small wattage tube amp), and push it harder within the iso cab... move more air, across a wider frequency.
bandwidth: 80 hz - 5.5 khz
You've definitely heard this one before! Inspired by the success of the 10" ALNICO (Legend 102), this version gives a 12" alternative. The ALNICO is famous for its warm Bluesy tone. This model is ideal as a replacement or for extending the power handling capabilities in vintage boxes. Expect a much thinner tone and a lot less body from these vintage reissues. These speakers were designed to recreate the 'Jensen' tone from years ago. They make great replacements in lower power vintage amplifiers.
eventually, i'd like to add a modded Fender Champ to this mix..
possibly, THD yellowjackets to the boogie (6L6's to EL84's) as well, for a completely different flavor...
