K
kylla
I was pondering a couple of things...
Can someone enlighten me as to the reasons I would use gold-plated connectors and cables? Quality? Durability? They don't degrade as much?
I was eyeing off the Audiophile 2496 soundcard which has gold RCA connectors. I was also eyeing off the Delta 44 which has standard 1/4" connectors in an external breakout box.
Am I right to assume 1/4" connectors (eg: those on the Delta44) don't come in a gold-plated flavour? Would using gold-plated Hosa cables with non-gold plated connectors be a waste of time, or is it a case of each part of the puzzle that is better quality leads to better overall quality?
Finally, does using an adapter to go from a 1/4" cable to RCA plug degrade the signal quality enough to noitice? My Korg has 1/4" outputs so I was hoping to have 1/4" inputs on the soundcard so as to minimise adatper plugs etc. Or is this being too fussy? (Most likely)
Just some curious thoughts.... cheers for any input.
