ChuckU
Right now I'm using two Delta 1010's and they work beautifully together. I routinely track 10-12 tracks simultaneously at 44k, 24bit onto an internal IDE drive thru a 2.4ghz with Sonar 2. I've done 16 with no probs. This has been my setup for a couple of years, but recently a power supply went on my PC and ended a session. I realize that PC problems are part of the territory, so I have since tried to purchase PCI cards for the Deltas separately. If I had another crash during a session I could have a backup PC standing by, needing only to switch the Delta parrallel cables. MAudio won't help me with this, nor will dealers. I've seen them on Ebay, but it's rare.
So, I'm thinking of going firewire. I thought about buying a Delta Firewire 1814 and a front end ADAT interface such as the Octopre or the Octane by Maudio. I know Behringer has one too. Cheap. This would give me 18 inputs and a one plug change out. Even easier if I record onto Firewire or USB2 drives.
Any thoughts on this? Is it a step back? Are there better options for PC? Any opinions on other gear I mentioned?
Thanks
Thanks
) the Behringer, then although I currently use one, I would recommend getting something other than
