Oh yeah, I'm running a VIA chipset and n-Track is a stable application.
Christ, I've only been running this thing for 3 years, and I've never seen a stable version after 2.3. Sure, if you just hit the record button and do some basic mixing it is pretty "stable."
Let me tell you what doesn't work for shit:
1) Live input processing. Not very well it doesn't.
2) Effect automation. Totally flakey.
3) Drawing volume, pan, and/or aux automation causes tracks to cut out during the mixdown process. There is no fix other than to completely reimplement the track.
4) Fruity VSTi doesn't work with anything less than 3.1.4, and it doesn't work well (random synch problems) even with the newest version unless you play some tricks with WDM, which sucks because I only use ASIO. Oh, and random crashes, yippie. Oh, and the multi-output version doesn't work at all.
5) The piano roll editor is a god damn joke. Crashes randomly (try dragging notes). Doesn't always trigger properly, nor does note length work right with all instruments. Doesn't grab note names from VSTi. Not to mention that it's very difficult to use.
6) Sample rate conversion is seriously flawed if you happen to have ears that can hear high frequencies. Not even that, it's mega slow.
7) Random crashes with certain VST effects and instruments, like
PSP Pianoverb which is one of my favorites. (Which works fine in other VST apps like Wavelab, mind you.)
8) Everything after 3.0.5 has taken a serious performance hit. Don't believe me? Well, you have to actually push your system before you can notice a performance hit. Most of my projects hit ~24 24bit tracks with heavy processing so every ounce of processor is very neccessary. I have a test project by which I can easily measure performance, and everything 3.1 and up is about 15% harder on the CPU than anything else, because now I get dropouts at 75% usage. Everybody is so caught up in which chipset people are using that they'd never think that the application is flawed.
9) When you hit the "Delete file" button when removing a track, the track is not deleted, and I've got scores of messy bloated folders to prove it.
10) Mixing down "live" produces static.
11) Aux returns are mistakenly routed back to the wrong outputs when using a Delta, and the only fix is to limit ASIO/WDM output to two channels. Haven't verified if this is still a problem on 3.1.6, but it is a problem with 3.0-3.1.
12) Ever since 3.0 the mixer has been a major CPU hog. He fixed it a little bit somewhere around 3.1 but it's still a major hog.
How many of those problems are an issue for me during a regular project? Almost all of them. I'm sick and tired of it. No more features that don't work right...if he'd concentrate on getting one feature at a time rock solid I'd be much happier.
Now I've personally gotten several bugs in n-Track fixed...most recently the "VU meters anticipate output" bug which also, not suprisingly, "worked fine for everybody" until Flavio recognized it and fixed it. I think it's great that flavio is supportive, but if he can't reproduce a problem, it doesn't exist and almost everybody at the ntrack site is such a damn fanboy that real problems can't be addressed without a major brawl.
My system is on a 440BX chipset, unarguably the most stable chipset we've ever seen in a DAW. I'm running Windows 2000 as well, and we all know n-Track loves 2K. I'm using a Delta 1010 which is a pretty damn typical system now that gadgetlabs is gone. I'm an engineer with a computer science degree so I'm vaguely familiar with using computers, and I know when an application pisses me off to no end.
It's not so much the program itself, it's that I've recommended it so much. I'm tired of recommending it, and I'm tired of the people I recommend it to coming here with all these bullshit problems that are extremely difficult to solve. I refuse to be "loyal" to ones and zeros. When n-Track works I like it, when it blows my night, I hate it.
I'm not giving up on n-Track, but I am through pretending like it's a nice stable little application. It's ok for 60 bucks and I'm afraid there's reall nothing else out there with all the features that I really want....so that doesn't help my mood any.
Sorry for being so negative,
Slackmaster 2000
