RecordingMaster
A Sarcastic Statement
Hey all!
I have some old acoustic foam sheets that are 3" thick and each 2'x4'. They are useless as I now have all broadband and bass traps using OC703. They are the old school king with the pill shapes on it. It looks like this but is yellowed. http://www.proaudio.com/images/sonex_classic_charcoal.jpg
Anyways, I was thinking I would stack them together side by side and then another layer on top of each other so they are 4'x4' and 6" thick. I would place them in a wood frame, cover in burlap fabric and add some feet so they stand upright. I have enough to make two of these. I would use these when wanting more "focused" sounding drum tracks without as much room tone, or to isolate two different instruments being recorded in the same room at the same time, or to put on either side of an electric guitar cabinet or behind acoustic guitar player while tracking to reduce some room tone as well. When not in use, I figure I could place them straddled in two of the room corners in front of my corner bass traps, to just absorb even more low end in the room while mixing, etc.
My only worry is, will this just deaden out all the high end too much on the source I am recording? I know thin foam does nothing other than reduce high end. But when going 6" thick, I am assuming (hoping) it evens out the spectrum a little bit? Where as I am absorbing more of the frequency range so it doesn't sound too much of one thing (ie too dead, too boomy, muddy, etc). I was thinking of putting a wood front and back on these and cutting various large holes, but then I'd worry this "gobo" will now have a reflective portion that may reflect back into the mic, making it sound as if I had the source right near a wall or hard surface and defeat the whole purpose.
What do the acoustics guys think?
Thanks in advance for the help!
