miroslav
Cosmic Cowboy
Is there any real downside to gluing down a bolt-on neck?
I know the idea behind bolt-on is that it's cheaper to make, and if ever the need came up to replace the entire neck...it's easy to do.
But the ability to replace a set-in neck is almost non-existent without some serious hacking...and yet, that's never been an issue, as lots of guitars now go with set-in necks...both inexpensive and expensive ones.
So...with some older (and current - like Fender) guitars that come with bolt-on necks...if the neck is straight-n-true, and without issues...is there any downside to gluing it down at the joint (along with bolting it in)?
Reason I ask...I've noticed that some bolt-on necks can "snap/twitch/pop" at times when playing a bit vigorously...or even with climate changes, so why not just dab some Elmer's in there and create a nice, tight joint?
