Nola
How do you do this if recording an album at home? It seems like every track I have is at a different volume. I guess this is what mastering does, so do I need mastering software to do this correctly?
If every song you have is a different volume, the mastering process takes care of that. But if they are similar material and wildly different volumes, you may want to revisit the mixes.
When mastering an album, it isn't necessary to make everything the exact same volume, you just want it to flow naturally from one song to the next.
Wondering the same thing myself. I assumed, perhaps wrongly, that he meant individual tracks in a single song mix.When you say "track", do you mean tracks in a song are all the same volume, or the (mixed) songs themselves are different volumes?
Yeah. I'm just trying to clarify that.Wondering the same thing myself. I assumed, perhaps wrongly, that he meant individual tracks in a single song mix.
Do they add some type of normalization if you don’t mix to a specific volume, and if so, will that change the sound of the mix?The basic idea is to make the volume and tonal balance for each song fit in with the rest, and also with other music of the genre. You also need to consider the delivery method. Mastering for CD is usually louder than mastering for streaming. You're not obligated to master to a specified volume unless a given release platform requires it.
If you master to a lower volume than a streaming service uses, they might raise the volume and limit down any peaks. That will change the sound to some degree, though it may be subtle.Do they add some type of normalization if you don’t mix to a specific volume, and if so, will that change the sound of the mix?
What mastering limiter plugins do you think are great?
Thanks!
quiet mix sounds better however it becomes weak when you burn it to a CD because they destroyed the format for everyone. When they master for a CD they soft clip and even hard clip with clip restoration. That is why it is very difficult to get that volume in the first place. Because the last thing we want to do is mutilate our own mixes. I figured unless I drop $8K into mastering equipment they are using I might as well send it to a mastering engineer that is worth its salt. Which I would recommend Massive Mastering.Is it me or does music sound better with a quieter mix and turning up the volume on your interface/amp?
