J
jazzadellic
Ok I spent hours searching and reading reviews on mic preamps and thought I had come to find the one that best fit my needs and budget with the Behringer MIC2200. But then I realized whoops I have no way to plug it into my pc. Is there a easy economical way to get it plugged into my pc? I tried running it through my cakewalk ua-1g and I got this high pitched humming sound. I assumed it's because the ua-1g was not meant to have a preamp plugged into it as it is itself, I believe a type of preamp. Any suggestions as to what would get the job done without having to spend too much? I mean i'm not even slightly experienced in using preamps, as you can probably tell. I'm not sure if I need one of those usb mixer things or if there is a simple solution like a usb adapter?
