L
luckymann
Hi there,
I'm recording to my Echo Layla 20 soundcard with Cubase SX. I usually try to reach for a whole-band sound, although I play all the different things (guitars, synths, drum machine and bass) alone. I could really use some info how to use my Bass Pod Pro(by Line6) properly to get it my bass lines recorded well...
I have a Fender Jazz bass (American traditional, one of the cheapo models), and I'm not a good bassist. However I can create lines, and play in rhytm. The songs I record I play are mostly melodic rock.
I've recorded my bass tracks by plugging the bass to the Bass Pod Pro, using a preset, turn the volumes up high (to get a proper signal level) and recording both the DI and modelled signals. Then at the mixing stage I mix those two mono channels. But my bass sounds really lack balls & and sometimes there are huge volume peaks ( I thought the presets already had the compressor). I can compress the signal afterwards with a plugin, but its not the same...the track looses something. I.e. I only get either muddy or very thin bass sounds. Without any real balls.
Some of you speak very warmly about the Bass Pod Pro... how on earth you get those great sounds you talk about? In which way do you record them? Would any kind spirit post some tested and proven setups & settings for getting even for one particular great sound out of the Bass Pod. It seems I cannot do it...
Regards,
Kalle (from Finland)
Regards,
