Getting a new sound card, suggestions please
  • Thread starter Thread starter ESPplayer7
E
ESPplayer7
my limit is 250 and i am looking into a really good sound card. I was thinking about either the audiophile 192 or delta 1010. i have no need for a bunch of connections like the 1010 but i see that the 192 does not have xlr inputs or word clock inputs. Can anyone suggest me something or give me an opinion on the two cards stated above, help appreciated
Anything by M-Audio is going to be good because they're a good company and their drivers are rock-solid. If you cannot see yourself needing more I/O than on the Audiophile, then get that. Neither of them have preamps onboard, so you'll need a little mixer or something as well. If you are literally just doing guitar and vocals then a Soundcraft Compact 4 mixer could be perfect for you - just not much use for anything else. Failing that, the Yamaha MG mixers and JoeMeek ThreeQ are the next two I'd consider.
the lower end "M" cards by EMU are a good deal....especially considering the nice A/D converters and a dedicated (but kinda mediocre) hardware effects processor.
I would'nt worry about wether the card has XLR inputs because most preamps/mixers have 1/4" or RCA ins/outs anyway. Hopefully you will be using a preamp between your mics and sound card. The 1010LT has two XLR inputs with 2 built in preamps, 6 RCA inputs, 8 RCA outputs, stereo digital ins/outs, and MIDI in/out. I can't say that the built in preamps are that good though. I wish that M-Audio would have just left those 2 channels like the rest of the inputs, RCA connections with no preamps.
You do need a mic preamp in your signal chain though. Like someone else mentioned, maybe a small mixer or something. Sound wise, I would get an Audiobuddy or two over a cheap mixer. One Audiobuddy will give you two mic pre's and two direct inputs for guitar/bass. With two of em, you would have 4 preamp/di channels to work with.
If routing options are more important than better preamps, get a mixer. I have the Yamaha MG 12/4. It does'nt sound bad at all and it gives me alot of routing options. I owned the Audiobuddy before getting the 12/4 mixer and I do think the Audiobuddy has better sounding pre's. Also, the direct inputs are nice to have, which you won't get on a mixer. Mixers have line inputs.
You said you have $250 to work with. I would get the Audiophile and an Audiobuddy preamp (about $260 new for both) or the 1010LT (about $220 new) and just work with the built in pre's until you can afford a decent preamp. Either way, you will only be able to record 2 tracks at a time but getting the 1010LT will give you the ability to expand up to 8 analog tracks at once.
Also, if you own condensor mics, you will need phantom power, which an Audiobuddy or a small mixer will provide. The 1010LT card does not have phantom power.
