I didn't know you could incorporate LAME into Goldwave. That's convenient
. I'm not sure about the bug with 320kbps in Winamp. I think read something somewhere that there is a caveat in the MPEG specifications at 320kbps. I'll see if I can dig that up somewhere. Most people either stick with 256kbps maximum, or use lossless compression for bit-for-bit archiving.
iDrive uses a secure connection so that no one is supposed to be able to "eavesdrop" on any information you transfer to and from. The message you're getting is just telling you that.
I doubt I'm that much more experienced than you are. I only have a little head-start on ya. Believe me, it all starts to come together with some practice and a lot of listening. I listened again later, and it struck me that I still wasn't hearing the dynamics I wanted in the song. I started to distrust my ears at that point, so I checked some other reference material side by side. Everything fine there, so I decided to cheat and take a peek at the wave form. If you have your stereo wav file in Goldwave, you should notice that there are some "peaks" that jut above the average level of the music, and then a mostly solid area at a lower level (the average level). You'll notice even on this mix that the difference between the loudest parts and the average level is fairly small, and the overall level fairly "flat" through the whole song. This verified what I was hearing and is probably due to too much compression and/or normalization on the final mix. For rock tunes and some other styles, that might be exactly what you're going for. But this song could use some "air" to breathe in. I took a peek at the first mix, and it was almost a solid block
. You backed off a lot (especially the level), but I still think it's too much compression. I'd like to hear a mix with no compression or normalization just to compare, if it isn't a hassle. It might give me a few suggestions.
On the acoustic, have you tried doubling it? It sounds like you have no problems in the consistency dept. Also, an EQ cut between 200 and 300 Hz can sometimes pull some of the mud out of acoustics. Those frequencies might sound great in the track when it's solo'ed, but it can become pretty messy when all the other instruments are in the mix. Okay, I've rambled far too much now
