stupidfatnugly
I found this list for general EQ and it has been really helpful.
I was wondering if there are some general compression settings for these instruments or atleast maybe certain settings that you would never use.
like you wouldn't boost your hi hat at 50hz or you would never apply a 6:1 ratio to something.
Kick Drum
Any apparent muddiness can be rolled off around 300Hz. Try a small boost around 5-7kHz to add some high end.
50-100Hz ~ Adds bottom to the sound
100-250Hz ~ Adds roundness
250-800Hz ~ Muddiness Area
5-8kHz ~ Adds high end prescence
8-12kHz ~ Adds Hiss
Snare
Try a small boost around 60-120Hz if the sound is a little too wimpy. Try boosting around 6kHz for that 'snappy' sound.
100-250Hz ~ Fills out the sound
6-8kHz ~ Adds prescence
Hi hats or cymbals
Any apparent muddiness can be rolled off around 300Hz. To add some brightness try a small boost around 3kHz.
250-800Hz ~ Muddiness area
1-6kHz ~ Adds presence
6-8kHz ~ Adds clarity
8-12kHz ~ Adds brightness
Bass
Try boosting around 60Hz to add more body. Any apparent muddiness can be rolled off around 300Hz.If more presence is needed, boost around 6kHz.
50-100Hz ~ Adds bottom end
800-1kHz ~ Adds beef to small speakers
6-8kHz ~ Adds high-end presence
8-12kHz ~ Adds hiss
Vocals
This is a difficult one, as it depends on the mic used to record the vocal. However...Apply either cut or boost around 300hz, depending on the mic and song.Apply a very small boost around 6kHz to add some clarity.
100-250Hz ~ Adds 'up-frontness'
6-8kHz ~ Adds sibilance and clarity
Piano
Any apparent muddiness can be rolled off around 300Hz. Apply a very small boost around 6kHz to add some clarity.
250-1kHz ~ Muddiness area
6-8Khz ~ Adds clarity
8-12kHz ~ Adds hiss
Electric guitars
Again this depends on the mix and the recording. Apply either cut or boost around 300hz, depending on the song and sound. Try boosting around 3kHz to add some edge to the sound, or cut to add some transparency. Try boosting around 6kHz to add presence. Try boosting around 10kHz to add brightness.
100-250Hz ~ Adds body
1-6Khz ~ Cuts through the mix
8=12kHz ~ Adds hiss
Acoustic guitar
Any apparent muddiness can be rolled off between 100-300Hz. Apply small amounts of cut around 1-3kHz to push the image higher. Apply small amounts of boost around 5kHz to add some presence.
Strings
These depend entirely on the mix and the sound used.
1-6hHz ~ Sounds crunchy
Kick Drum
8-12kHz ~ Adds Hiss
Snare
Hi hats or cymbals
Bass
8-12kHz ~ Adds hiss
Vocals
Piano
8-12kHz ~ Adds hiss
Electric guitars
8=12kHz ~ Adds hiss
Acoustic guitar
Strings
