Glad to hear you got a hip box--not much of geek anymore, and not hip with the latest cpu and ram --- but glad for you that you have the "headroom " with your system to get things done. Been building the dual core boxes for 300 to 400, or so, and haven't dared to look at the nicer and finer stuff out there. The dual core parts and cpu are cheap enough for me to justify getting, saving some money, but getting slower machines,,,,,,there may be a trade off issue in here somewhere for me.
two pc's are connected via a giga-port connection, or the amount of plugins you can use will be limited. You will also need a giga lan straight thru cable (Best Buy).
. Works well, and someone with a couple of older rigs, it would be a good thing to try.
giga ports--your referring to network thru-put, right ( ? )--you think the normal 10/100 ethernet ports handle a good load of vst work ?? My hub is just 10/100----would like to give this thing a try like you did,.....
i'm kinda in this wierd thinking mode about this---I'm turning into a "cpu" farmer, growing machines and farming out the vst's......i dont know, kinda wierd, cause its not something i foresaw........heck there once was a time when it was just fun to find a bottle, find a simple record button, and jam.....this is not the tape portastudio anymore--got a little too much going on---with the technology. just venting.
thanks for your help with remote. hope you use ear protection with your axes and that head in your avatar......it looks like its powerful enough to shake the insides of your lungs a bit--
---which is a feeling that I truly enjoy.
