FRUITY LOOPS newbie question
  • Thread starter Thread starter Mountainmirrors
M
Mountainmirrors
kaleidoscopic renegade
Hi-
I've tried out Fruity Loops and was able to put together some fine, fine beats, but how do I then sequence them and form a complete tune? (to then import into Cool Edit)
Rather than play around for hours, I figured I'd just ask here...
You guys are always fantastic with helping.
Thanks!
-Jeff
You have two options here. You can open the playlist editor in Fruity Loops, which will let you arrange your loops however you see fit. When you are done, you could then export the arrangement as a wav file. Your other option, and this is what I do, is render each loop as a wav file, and then use it in some multitrack program, such as Vegas, Cubase, etc...
